Hi JIRA, I am trying to customize my dashboard with custom filters, but every time I try to save my new Advanced filter it erases my changes.
Can someone explain why this is happening and/or a workaround so I can use advanced custom filters? Thanks!
I have had this same issue and found this thread while searching for an answer. The work around is to click enter after you finish your edits, and then click the Save button. Really annoying bug, but it is working for me now.
Can you click search after making the changes, before trying to save it?
Hello
Strange behavior. Are you able to save other simpler filters at all?
