Used to be able to upgrade issues from stories to epics or bugs to improvement issue types. Now i cannot. Did something change on Jira Cloud recently?
Can you try the "Move" operation? It will ask you to change the fields values, status etc depending on the target issuetype.
Hi @Bar T
Do the issues all share the same workflow? If they don't you will have to use a bulk update to change the issue type.
