Why can't I close an issue without leaving a comment?
Morgan Thunder
We have encountered what appears to be a bug where an issue would not close unless a comment had been left in the comments section. There are not validators on the workflow transition to closed. Why would this be?
4 votes
Michael Partyka
March 15, 2016
Hi Morgan,
maybe you have condition in your workflow?
Upload your workflow here I will check it.
MattS
March 15, 2016
For humans, this is a good thing. It means that some colleague doesn't have to contact you three months later to ask why you closed it. For service accounts, it's a bit annoying but not too much.
My money is on a Behaviour making this required
Nic Brough -Adaptavist-
March 15, 2016
When you say "would not close", what is the actual behaviour?  Is it churning when you click the commit?  Returning you to the issue view with nothing changed?  Error message?
Morgan Thunder
Hi Nic - I should have said - no error at all. Just nothing happens when you press the commit button. Then when you go back and add a comment, the button works and the issue closes.
March 15, 2016
Hmm.  Do you have any custom javascript, or the Behaviours add-on installed (it's part of Script Runner now)?
Morgan Thunder
We do have Script Runner (and Behaviours) installed, yes.
March 15, 2016
Ok, check the list of Behaviours that may be active - on a very old version (before it merged with SR I think), I remember managing to set up a behaviour that would do exactly what you're seeing - it was requiring a comment during transitions, but not telling the user why it wasn't letting them proceed (because I'd made a mess of the config)
Morgan Thunder
Thanks Nic, I'll check it out.
