Hello @Venkata Subbarao Harish Nimasakavi
The error message you're seeing indicates that the current Jira plan has reached its maximum number of allowed users. To add more users, you'll need to upgrade your Jira plan.
If you need help with the upgrade process or have any other questions, please let me know.
Shreeja
Thanks @Shreeja J my concern is can we add extra users in jira after billing is completed. Now in our organization the active users are 79 and billing is done for that 79 users , can we add new users now. Just to know how many users can we add in Standard plan.
Harish
In the Jira Standard plan, the maximum number of users allowed is based on the tier you've selected during your subscription. Since your current billing is completed for 79 users, you would need to upgrade your plan to the next tier to add more users.
Shreeja J
Hello @Shreeja J
I need to clarify that if we remove some users from active users list, then is it possible to add new users in jira. Please help me on this with full clarification.
Thanks ,
Harish
Yes, if you remove some users from the active users list, you will be able to add new users without needing to upgrade your plan. The total number of active users must remain within the limit of your current plan, which in your case is 79 users.
Here's how it works:
Please make sure to review the users you deactivate to avoid disrupting any ongoing work or access rights.
Let me know if you need any further assistance.
Shreeja J
