Why do I receive status code 410 Gone from tempo api?
andonealexandru19
October 24, 2024
I am using the following endpoint in a process of syncing worklogs between 2 platforms: api.tempo.io/core/3/worklogs/jira/{worklogId}.
Everything worked perfectly for a long time until a few days ago when this endpoint started receiving 410 Gone. The code in charge of this process was not changed in a long time. I am using a build from more than half a year ago. The api token is still valid.
Salih Tuç
October 24, 2024
Hi @andonealexandru19, welcome to the Community!
Tempo recently sunset the v3.0, so you need to update your requests from 3 to 4.
Besides the performance changes, it is mostly the same API. The key difference is, v4 is not returning (and/or using) any text-like attributes that you can access through ids: such as issueKey, user's display name etc.
You can change your url directly to v4 and test the code. If code is working fine and you are sure that you are not using issueKey, then probably there is no problem.
For more details, you can check Tempo documentation  about changes between v3 and v4.
Oddvin Røsand October 28, 2024
Hello @Salih Tuç
For a new site we experience 410 for
https://api.tempo.io/core/3/account-links/project/<PROJECT_KEY>
This works for existing sites. And this endpoint is not mentioned in the link you provided. Is this also end-of-life? Where can I find documention on this? And how come it works for some sites, but not for new ones?
For the new site I got what I needed using
https://api.tempo.io/4/account-links/project/<PROJECT_ID>
But how urgent is it to fix our code so the integration towards Tempo don't stop working for existing sites?
Best regards,
Oddvin
Like • Kenneth Juul Wannebo likes this
Salih Tuç
October 29, 2024
Hi @Oddvin Røsand ,
As I stated in the first message, Tempo is announcing the changes and sunsets from their documentation. An endpoint may not changed at all and you can still use the earlier version, this is your decision.
However, as a best practice, I suggest to use only one version of the specific API that you are using. So, if you changed one endpoint to v4, I think you should change other ones to v4, too. Version changes are usually brings efficiency and easy access to some specific features.
In summary, you can still use the v3 since it is responding, nothing urgent right now. But, I strongly suggest that you should update it to v4 asap :)
Have a nice day!
Like • Oddvin Røsand likes this
Oddvin Røsand October 29, 2024
Thanks for your reply!
I've been in contact with the Tempo team, and they could confirm that they disable v3 of their api for all new installations. That is the reason why we get different experience for different sites using the same code.
We have started a task of upgrading our implementation of their api from v3 to v4. While waiting for this task to complete I got Tempo to whitelist the sites where v3 was disabled for a limited period of time. This way our code works ok until we get our code to support v4.
Best regards,
Oddvin
Like • Salih Tuç likes this
Salih Tuç
October 30, 2024
Thanks for the reply and the follow-up information. If you face with any challenges during that time, please don't hesitate to ask your questions in the Community!
Cheers.
