Why do see Two Transition Tabs
Sterland Admin February 4, 2020
We are upgrading from JIRA V7.3 to V8.5.1.
While testing we are seeing two transition tab.
How can we only display one.
David Fischer
The first tab is from the JSU app, the second one from the JMWE app. The second one has a small JMWE logo in the bottom right corner, and displays more detailed information.
To disable JMWE's tab, go to the JMWE Configuration page. To disable JSU's, I believe you need to go to the Manage Apps page, locate JSU, open the details, and click on the "+" next to "xx of yy modules enabled":
Then scroll down to the Transitions Summary Tab Panel and click on "Disable":image.png (the Disable button appears when you hover over the line)
Ritu Garg February 24, 2020
Thanks, your suggested solution worked perfectly.
John Funk
February 5, 2020 edited
Hi @Sterland Admin  - If you have JMWE, then the second one is probably from that. The first on is the standard Jira one.  If you see Time In Status as the column on the right instead of Execution Time, the Time in Status one is JWME.
David Fischer
Actually, one is from JMWE, and the other is from JSU.
JMWE's has a small JMWE logo in the bottom right.
Like • 2 people like this
John Funk
@Sterland Admin  - did these answer your question?
Noureen Stephens May 12, 2020
Yes it did and I disable the "Transition Summary Tab Panel"  it via the JSU.
Jack Brickey
I am betting you have some addon that is presenting the second tab. What data is under the second?
Register today
