I just created a story for a new agile project i created on On Demand Instance.
But after creating the story i am not able to view edit/more options/start progress fields on the story page. (image attached)
Can you please help me with this?
Looks like your permission scheme only allows you to create issues, not edit or move through the workflow.
Thanks Nic for responding.
Just found the solutions to this: I added myself in roles section from the administration page and all the options started appearing for me.
It seems that by default your name (even if your are an admin) does not appears in roles section when you create a new project.
Ahh, ok, so your permissions probably work out as "Anyone with a login can create issues, but only people in roles can do the edit/workflow etc"
