Hello!
I the `withNextDayOfWeek()` function does not seem to work when directly using a custom field. The custom field is a list that has days of week like `MON`, `TUE` as expected in the documentation.
{{issue.DueDate.withNextDayOfWeek(issue.customfield_11069).plusWeeks(issue.customfield_11068.floor.minus(1))}}
I could successfully get this to work by creating a variable first, and then just using that in the function. Is there some magic going on why a single select list would not just be a string?
Thank you! --Flo
You describe your customfield_11069 has a list of days of the week. Is it a single-select, option field?
If so, please change your parameter to explicitly use the selected value. Otherwise I believe the default attribute returned is the id, such as 1, 2, 3...
issue.customfield_11069.value
Learn more
