Why is my IF statement being ignored in automation?
Glen Cochrane
I've read similar questions and answers but none have helped me. My scenario and rule seems very simple and I cannot see why it fails. It has worked for other projects when cloning between JSM and JWM projects.
  • In our JSM project, when an issue transitions from In Progress to Under Review we want the issue cloned to a Product Discovery project as an Idea.
  • The JSM workflow allows for (requires) the issue to move out and back in to Under Review.
  • To prevent duplicate clones, I have an IF statement to ignore issues if linked issues exist of type Clones or Is Clone By (screenshot below).
  • The problem is, upon re-transition to Under Review (linked issues now exist) the automation is ignoring the IF statement.
  • The cloning shouldn't occur again.
Rule details:
  • Scope = Multiple Projects (includes the two reference projects)
  • Trigger transition statuses only exist in the one JSM project
Thanks for your help :)
Glen
January 12, 2024
Hi @Glen Cochrane
Looking at your rule and audit log images...
Is this rule defined in the ZPT project, or as a global rule with multiple-project (or global) scope?
If it is defined only in ZPT, I believe the links cannot be "seen" because the other project is out of scope for the rule.  To solve this, move the rule / change the scope to include both projects.
Glen Cochrane
Hi @Bill Sheboy ,
In my OP description, I noted:
Rule details:
Is this what you mean?
It is a multiple project rule and the two projects ZPT and APID are added as its scope.
January 12, 2024
Thanks; I missed that part, as it would certainly cause that symptom.
Your audit log image shows a configuration change in the rule between what I assume was the successful run at 11:54:04 am and the incorrect one at 12:02:39 pm.  You note the change was inconsequential; what changed?
Another way to test if those links are visible to the rule (or if the condition is broken) is to use a Lookup Issues action with JQL and the linkedIssues() function, testing for the exact link type.  If the lookup returns issues when the condition does not work, that would confirm the condition is not working as expected.
Glen Cochrane
Hi @Bill Sheboy ,
The inconsequential config change was editing the rule description.
However, since the 2nd failed run I realized that while I had the automation set as Multiple Project and had the two projects added, my IF statement was only naming the ZPT project.
I added the APID to the IF condition restriction and that seems to have been the fault. I wasn't considering that the IF needed to "see" APID at this stage.
Thanks all for the input and help!
Glen
Like 2 people like this
Mark Segall
Hi @Glen Cochrane - Can you please share a screenshot of your audit log for this rule?  It would help us understand what's happening.
Glen Cochrane
January 12, 2024 edited
Hello @Mark Segall - thank you for the response.
Below is a screenshot of the two rule runs. (The config change seen inbetween is inconsequential).
Also note, the error of "Unknown field = Attachment" is false; a known bug. The attachments do clone to the new issue.
Register now
