Why is my Visual Studio Code not showing Jira Issues?
Vitus Petersen
December 22, 2024
Hello everyone, I'm having a little problem with Jira, as the issues don't get displayed properly. First of all, "SPACE" is not the tag of my current project, it's "TTM", and TTM is the only project under Sampi Studios.
Secondly, I do have a different group, but I can no longer see the tasks inside of Visual Studio Code, it just ends up like this, and it stays like this
And if I try to create an issue through VSCode, this is where it gets stuck:
I have tried all the combinations that I'm aware of, uninstalled VSCode and the extension several times, restarted the computer, messed with settings, but nothing has worked so far. I hope someone here knows what the problem is
Best Regards,
Vitus
Nathan Phillips
December 26, 2024
While Jira Cloud does not directly support VSCode and this extension, I would recommend maybe reaching out to the Atlassian Developer Community as you may have more luck getting answers related to this topic.
Wishing you the best of luck!
Lucas Modzelewski _Lumo_
Hi @Vitus Petersen , welcome the Atlassian Community!
In VS Code extension check if you imported all filters, if you don't see what you need then you most probably need to create a filter for issues from that project.
Vitus Petersen
December 26, 2024
It seems to include everything, am I wrong? Just for clarification, I am actually assigned to the issues
