Sign up Log in
Why is the layout of the issue details page confusing?
Jane Zhou May 14, 2023
Jens Schumacher - Released_so
May 14, 2023
Hi @Jane Zhou
The screenshot looks like it's coming from a local server instance. The highlighted content appears to be an app that might be messing up the layout. If you control the app, you can try to fix it or alternatively uninstall it.
Jens
yeah this is a app i developed, but i don't know how to fix it
share my codes here
<web-panel name="remoteview" i18n-name-key="remoteview.name" key="remoteview" location="atl.jira.view.issue.left.context" weight="100">
<description key="remoteview.description">The remoteview Plugin</description>
<resource name="view" type="velocity" location="templates/remote-view.vm"/>
<label key="remoteview.title"/>
</web-panel>
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<title>remote view</title>
</head>
<body>
<div class="frame">
<input id="link-submit" class="text" name="submit" value="">
## <button class="aui-button aui-button-primary" id="button-spin-1" onclick=doAjax() >Add</button>
<button class="aui-button aui-button-primary" id="button-spin-1" onclick=doAjax()>Add</button>
<table class="aui">
<thead class="table-dark">
<tr>
<th>Joint Name</th>
<th>Create Time</th>
<th>Creator</th>
<th>Manage</th>
</tr>
</table>
</div>
</body>
</html>
will appreciate it if it can be fixed
##<!DOCTYPE html>
##<html lang="en">
##<head>
##<meta charset="UTF-8">
##<title>remote view</title>
##</head>
##<body>
<div class="frame">
<table class="aui">
<tr>
<th>Joint Name</th>
<th>Creator</th>
<th>Manage</th>
</tr>
</table>
</div>
##</body>
##</html>
 I changed the .vm into this and solved
