Why my issue resolutions still unresolved
Ratih Ebtania January 22, 2025
Hi Team
I have questions, I made workflow when card move to UAT Done or Released that set as Done. But why when I need to released the versions the card still unresolved status.
Please kindly help to check
Thank you
2 accepted
Ollie Guan
Hi @Ratih Ebtania ,
There are many native functionalities in Jira that depend on the "Resolution" field. Some of them are (and they are not restricted to):
  • Issues having its key strikethrough on boards;
  • Reports about issues (for example, "Created vs resolved");
  • System filters (for example, "Open Issues").
Best practices on using the "Resolution" field
https://confluence.atlassian.com/cloudkb/best-practices-on-using-the-resolution-field-968660796.html
Thank you @Ollie Guan I will read the document first
Like Ollie Guan likes this
Vishal Biyani
January 22, 2025
@Ratih Ebtania
did you check if all the subtasks are marked as Done?
all cards did not have a subtask @Vishal Biyani
Victor Law - Ricksoft
Hi @Ratih Ebtania
Can you please verify if the Resolution field is set for the Jira issues you refer to?
I suspect there is no value set for the Jira issues.
https://confluence.atlassian.com/jirakb/unresolved-showing-up-as-a-resolution-for-resolved-issues-163938438.html
Thank you.
