×I put a screen between transition and when I fill the extra fields and click in transition button, this error appears:
Someone could help me to understand why this is happening and how I could solve it?
There are several things that might be happening here.
They are all related to the app mentioned (by its class name, not its actual name - ru.andreymarkalov.atlas.plugins. A bit of digging I wouldn't expect from most people to do can get us to tell you it's Appfire's Power Utilities for Jira workflow )
This app either
I would want to check the App's status in "manage apps" first, to check the first two, but the third one needs a bit more thought.
Now, the weird bit is the actual error - it's about a search being run, which is not something that normally happens during a transition. It makes me think you have a validator or post-function that tries a search for some reason. And that search is malformed or being passed dodgy parameters. I think we need to see the config of the transition you are executing!
This sounds like an ancient version of the plugin. SearchResults used to hold List<Issue>; and SearchResults#getIssues() could have been used pre-Jira8
Since Jira8, this was removed in favour of List<T>, and the #getIssues() method effectively changed to #getResults()
https://confluence.atlassian.com/jiracore/lucene-upgrade-975041047.html (search for 'SearchResults'; this is from "Preparing for Jira 8" release notes)
Ergo, the app is very very outdated, and this particular workflow validator/function will not work unless the plugin is updated.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
