When I change the key of a project to different one, will it break the automation? (newly integrated addon into Jira).
While editing the project key is a major change, in most cases, your JIRA project will work as you'd expect with a new key. There are a few cases that you should be aware of, which are listed below. We recommend reviewing these and advising your users accordingly.
<JIRA Home>
\data\attachments
directory) will retain the old project key. For example, if you change a project's key from TEST to DEMO, the attachments will be stored under <JIRA Home>
\data\attachments
\TEST
.If you export a renamed project, and then import it, it will have the updated project key, i.e. the original project key will not be retained. In fact, all historical keys for that project will be removed.
