Will the display of sub-tasks ever get fixed?
Jeremiah
Ever since the visual update, sub-tasks got a little love when it came to showing specific columns and widths on the parent task, but now there are scrollbars all. the. time. Despite adjusting column widths, removing columns. No matter what there's always two scroll bars. Vertical and horizontal.
Oleksii Melnyk
June 30, 2025
Hi @Jeremiah .
What happens if you try to reduce the scale in the browser itself? Maybe you have a small screen resolution?
Jeremiah
Good thought. However, the issue still persists no matter what my zoom level is or browser (Chrome, Edge, Firefox). However, with Firefox the scroll bar is significantly smaller, but still present.
Oleksii Melnyk
June 30, 2025
I just checked on my site. I also have these scrolls. All I found is that if you change the size of the columns, so you can make the scroll bar 100% and not moveСнимок экрана 2025-06-30 в 23.40.35.png
Jeremiah
Hence my question. :)
