I created a new Issue type called Build. I copied the project's existing issue type scheme, added "Build" to it, then associated the project with the new scheme.
I want issues of type "Build" to use a different workflow than other issue types in the same project.
I thought I could do this, but now that I am attempting to implement it, I can't figure out the right sequence of events. Maybe this isn't possible?
Thanks for your help.
Yes you can do this. Please find the link below for details https://confluence.atlassian.com/display/JIRA/Configuring+workflow+schemes
The key is create a separate workflow scheme and associated with the issue type.
Cool. I had the new workflow created. I couldn't figure out where to do the link. All working now. Thanks!
Please Tell it is Possible to Create to different workflow on single Project with Different kanban board
Please do not mix up oroject, workflow and boards, they are all different things.
So, workflows only interact with boards by telling them board what status issues can have.
To "Create to different workflow on single Project with Different kanban board", as best as I can understand it, create two workflows and put them in a scheme so that you have two different issue types following different flows. Use that scheme in one project. Then set up the two or more Kanban boards you need and tell them to look at that project.
The only project type that currently supports multiple Boards & workflows is the Classic Software Project. A Classic Business allows only one Workflow, and will automatically build its board to match it. Any Next-Gen Software project does not use a workflow, and therefore cannot be configured in the same ways.
Hey guys,
I found that we can create a different workflow for different projects, but cannot see how to create 2 & more workflows within 1 project, so I still фиде to see all on my dashboard.
Do you have any thoughts how I can do this?
Thanks, Platon
Look at the "workflow scheme" for the project. This maps workflow on to different issue types for the project you use it in
while I had created two workflow on single Project But when i am Creating Issue on 1 project then it is visible to another Board
I created a workflow for project A
Project B is using project A board
Then in project B i switch to use project A workflow.
I notice in project B the status is duplicate. I.e in progress will have additional in progress (2) . To do will have another to do (2)
Learn more
