Work Request in Scrum Board
Sophia Skinner June 19, 2025
Hello Atlassian Community
I am looking for a solution to manage requests from external teams. Is this possible without service management? Right now my team manages work with a scrum board and external teams make requests to this board by creating new tickets directly in the backlog. The issue I am facing is that there isnt a lot of consistency with the information that's included in these requests and there is a need to delineate categories for different request types which may be better managed through a form.
Is there a way to link requests via form to my scrum board?
Thank you!
Vitalii Rybka
June 19, 2025
Hi Sophia,
Yes, you can definitely do this without JSM! Here are a few approaches:
Option 1: Jira Forms (Built-in)
  • Create Jira Forms for different request types
  • Forms automatically create issues in your project
  • You can customize fields, make them required, add descriptions
  • Issues flow directly into your backlog for grooming
Option 2: Issue Templates + Restricted Creation
  • Remove "Create Issues" permission for external teams
  • Create issue templates with required fields
  • External teams request via email/Slack, you create using templates
  • More control but less self-service
Option 3: Separate Intake Project
  • Create a simple "Requests" project with forms
  • Use automation to move approved requests to your Scrum board
  • Gives you a triage/approval step
Option 4: Custom Request Types
  • Create different issue types for different request categories
  • Customize create screens per issue type with required fields
  • Still self-service but more structured
I'd start with Jira Forms - they're perfect for this use case and integrate seamlessly with Scrum boards. You get the structure you need without the JSM overhead.
Trudy Claspill
Hello @Sophia Skinner
There is a Forms feature available for Jira Software projects. Have you looked into using that?
https://support.atlassian.com/jira-software-cloud/docs/collect-information-for-your-team-with-a-form/
