Workaround for getObjectConfiguration () method of jira service in jira 6?
kishor nanaware February 16, 2014
Hi All,
I am migrating jira 5.2 to 6 .We do have some one customize plugin .It has been regiter in services But I am able to use method getObjectCofiguration("","","") method As it is depercreated.Is there any work around for the same.
kishor nanaware February 19, 2014
Thanks Mitchell,
I t work fine
Graeme Mitchell
Ok. Please make sure you accept my answer so people know this quesiton has been solved.
Graeme Mitchell
To "accept" the answer, you need to click the "tick" button next to my answer above. You've liked my comment which isn't the same thing.
Graeme Mitchell
I'm using version 6.1.4 of the API and the getObjectConfiguration method is not deprecated for me. I'm using getObjectConfiguration(String arg0, String arg1, Map<String, String[]> arg2). Structure of my service is something like this:-
public class myClass extends AbstractService
    public ObjectConfiguration getObjectConfiguration() throws ObjectConfigurationException
		 return getObjectConfiguration("SOMEIDENTIFIER", "somefile.xml", null);
	@Override
	public void run()
		//  DO SOMETHING
Register now
