In my workflow, the validator checks if transition from Waiting and In Progress contains a value in the Label field.
If empty, can I display a custom screen where the end user can get the Label field in edit mode - to solve the empty field problem...?
Kind regards
Ilanguak Olsen
Hi @Ilanguak Olsen, welcome to the Atlassian Community.
You can attach a (custom) screen to a status transition (click the arrow in the diagram representation of the workflow you use in the project). This screen can hold your custom field to be set by the user doing the transition. You can make the custom field mandatory as is described here: Solved: How to make a custom field mandatory in 1 project.
Hope this helps you,
Dick
Hi @Dick
After a short trial and error session, it was exactly what I was looking for. Even though it is quite easy - when you know it, it isn't that obvious.
Thanx a lot.
Ilanguak
I'm glad you got your bearings, @Ilanguak Olsen.
Don't forget, this community is a treasure-trove when it comes to helpful answers. Thank you for marking the answer, it makes this solution easier to find for people with a similar question.
Dick
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
