Workflow: If/Then Condition... to review or not
DSell
In using a simple workflow as shown below, what is the best way to eliminate the direct move to "done" if the issue type requires a review? Such as a bug where it must go through a review before moving to done.
Note: We do use scriptrunner.
Andrew Laden
October 17, 2022
Use a condition on each of the two transitions outbound from In Progress. One of them could be "IssueType = bug" and the other "Issuetype != bug"
A condition on a transition will only present the transition to the user if the condition is true.
