Workflow Step Ask For Resolution
bjordansb July 24, 2014
We're trying to make our workflow work so that if you set the status to "Done" or "Archived" you're asked to set the Resolution. When the transition goes to "Done" the resolution is set to "Done". I'd like it to ask. Or at least ask for the resolution when "Archived" is selected. There are some items we don't implement, can't reproduce, etc. I need this recorded in the workflow.
See Screenshot below of workflow.
I've seen this on boards before. When you move through the workflow it will ask you to set the resolution, flag time, add a comment, etc. However I cannot determine how to set our customworkflow up to work this way.
I'd really appreciate any help. I'm trying to understand workflows and transitions. I'm having a little trouble with the nuances of it though.
Andris Grinbergs
July 24, 2014
For Done: Edit all transitions to "Done" - add postfunction "Update Issue Field" (Field: Resolution, Value: Done)
For Achieved: Edit all transitions to "Achieved" and set "Resolve issue Screen" as Transition view.
Andris, Thank you so much. I'm still not 100% sure I fully undestand the relationship between workflows and transistions. Your answer did help me resolve my issue. I apprecaite it.
Andris Grinbergs
July 24, 2014
Workflow is kind of a image you attached.
Statuses are boxes in it.
Transitions are arrows in it.
