One of ongoing annoyances of Jira Workflows is Resolution and Resolution Date. Did you edit the workflow, and add another "Category Done" status? Forget to edit the transition to also set a Resolution? Cleaning that up not only sucks, but since you can't directly update the Resolution Date, you'll forever have an odd date spike once you update all of the effected items.
How about a validation that checks all of the transitions to a Category Done status, and if it doesn't set the Resolution status, give us a warning?
We should constantly check and track our work status on the Jira board.
