Workflow Validator Not Working As Expected
clem
June 9, 2016
I am try to create a workflow validator but instead of getting the message I put in my code I get
This is my code:
import com.atlassian.jira.issue.link.IssueLinkManager
import com.opensymphony.workflow.InvalidInputException
import com.atlassian.jira.issue.IssueFieldConstants
import webwork.action.ActionContext
def issueLinkManager = ComponentAccessor.getComponent(IssueLinkManager)
log.error("Outward Link: " + issueLinkManager.getOutwardLinks(issue.getId()).size())
log.error("Inward Link: " + issueLinkManager.getOutwardLinks(issue.getId()).size())
log.error("All Links: " + issueLinkManager.getIssueLinks(issue.getId()).size())
if (issueLinkManager.getOutwardLinks(issue.getId()).size() > 0){
throw new InvalidInputException("You cannot delete an issue with 1 or more links.")
Instead it gives me:
It seems that you have tried to perform an illegal workflow operation.
If you think this message is wrong, please contact your JIRA administrators.
Robert Dzido _Almarise_
June 9, 2016
Do you have any screen configured in your transition?
If you don't have any, message is a little confusing. When you add a screen it will look much better.
You can also use Workflow PowerBox Plugin which delivers "Number of related issues validator" you can configure without scripting smile
clem
June 14, 2016
Thanks.  I can see the error I throw now with my transitions screen.
JamieA
June 13, 2016
As Robert says, you get this message if you try to add a validator and there is no screen configured. Possibly it only happens when you specify that the error message should be associated with a field. It's a JIRA bug.
Azfar_Masut
July 11, 2018 edited
Hey Jamie,
Do you know of anyway to remove the default error messages? I want only the message configured in the scripted validators to be shown. Not using condition for this as I want the transition for the workflow to be shown. Using condition will just hide the transition for users outside those roles, can be confusing for new users
Like • Adam Zsiros likes this
Arjunsingh Hajari March 28, 2019
Yes @Robert Dzido _Almarise_  is right on the screen also you can post the error message
Help us plant more trees
