Workflow condition multiple values or same field twice?
Greg Sanderson
May 14, 2021 edited
This is about Workflow conditions, to limit where people can move the issues based on status. So I'm trying to use "Add condition to transition" and using "Field Value" option.
Requirement:
I want to stop issues being transitioned at all once they're resolved. In my workflow I have about 10 status, and two of those are status that represent a "resolved" state - "Done" and "Cancelled".
Ideally I'd like to just set a condition that stops moving an issue FROM a status but this doesn't seem possible. Alternatively I'll set a condition on ALL status stopping a transition TO them if Done or Cancelled.
Attempts:
I've successfully setup a condition that does this for one of them: "status != Done", and this works fine. However this doesn't cater for "Cancelled" and I can't find a way to cater for both at the same time.
Problems/Limitations:
  1. I cannot use a single condition to search for multiple values, e.g. I can't do "status != Done OR Cancelled"
  2. I cannot use "status" in a second condition to lock out "Cancelled", it seems if "status" is used in one condition it's just not visible in another condition
  3. I cannot condition based on "resolution", which would cater for both scenarios.
How can I achieve this please?
Fabian Lim
Hi Greg,
- You need to set your conditions to "All of the conditions" at the main level.
- Then create your first field condition to != Done
- Create the second field condition to !=Done
- If all conditions match, then the button will display.
The following video explains in details step by step.
Link: https://www.youtube.com/watch?v=1ZKVN0VeaB4
Greg Sanderson
Thanks for the reply. I tried both settings "All" and "Any" and when trying to add the 2nd condition "Choose field" does not show "Status".
It simply will not let me use the same field in two separate conditions
Heather Ronnebeck
Have you tried doing
status not in (Canceled,Done)
I’m sorry but I’m not fully understanding what you’re doing but I do know the jql needed to capture or not capture multiple statuses.
I hope this helps you.
Greg Sanderson
I've updated my question to add:
So this is on Workflow Condition field value option. There is no "in" or JQL, just basic = != > < etc
