I have added a status of "In Progress" category. I have added one transition from To DO to deferred state but unable to add back a transition from deferred state to To Do.
error is displayed "You cannot perform this operation on a draft workflow. Please help.
Hi Aamar,
Is the workflow associated with a project already?
You will need to copy the workflow, make your changes, then associate this new workflow with the workflow scheme.
An active workflow is a workflow that is currently being used by one or more projects.
When you edit an active workflow, JIRA first creates a 'draft' of it.
You can't do some things with draft workflows. Louise has already answered this question
@Nic Brough It would be kind of you if you could look into the query.
