Hi togehther,
I hope someone can help me. I want to setup a property on a transition. In the case that I will close an issue, I don't want that anybody can change the issue after this.
I used the property key jira.issue.editable with the property key value "false" for this.
I checked it and set an issue to this transition, but after this, the issue can still changed by everyone.
Where are my mistake?
Regards
Nadine
Did you set this property to the status or transition? This is supposed to be entered on a status: https://support.atlassian.com/jira-cloud-administration/docs/work-with-issue-workflows/#:~:text=the%20workflow%20designer.-,You%20cannot%20directly%20set%20the%C2%A0issue.editable%C2%A0property.%20To%20do,.,-The%20workflow%20designer
Hi Alex,
I set it to the transition that was the mistake. Now I set it to the status and it works.
Many thanks.
Nadine
