Is there a way to restrict which statues from a central status a user will see based on the value of a field?
So
MAIN STATUS
status 1. status 2
if a desingated custom field says send to status 2, the user will ONLY see status 2 to transition to
Hi @BrentBot - Yes. You would use a workflow transition condition based upon the value of the field.
Thank you Mark. Testing this now. what would be the comparison type i would compare it to?
the field value will be either 1, 2, or 3
Ignore my question. it was dumb
