Hi there,
When I add a description for an workflow transition, it should be showed when it has a mouse over the transition before select. (It works in JIRA datacenter, but not in JIRA CLoud).
Is there something I am doing wrong?
steps:
1 . edit and workflow
2. edit a transition (ie: Start Progress ) - from ToDO to In progress status
3. add a description to the transition (ie: start working on this issue)
4. publish the work flow
5. go to an issue that matches this workflow ( in to do status for example)
6. Select the status menu to show the available transitions
7; Mouse over the Start Progress transition
You will not see any popup tip about the transition description (step 3)
NOTE: If the transition is an workflow action it works perfectly
(https://support.atlassian.com/jira-software-cloud/docs/transition-an-issue/#Transition-an-open-issue)
For JIRA datacenter it also works perfectly
Hi @fbeck_br ,
I have never actually seen that in Cloud. TBH, I never use the Description field. I tested and verified your observation. I checked JAC and did a quick Community search. Neither turned up anything. It might be worth sending the feedback to Atlassian or opening a support request.
