Hello community members,
For a use case, we need to apply the regular expression check validator in the workflow on a single select field. The field has 3 values:
We need the validation to pass if the value is not 'NO'. We have tried the option as suggested in the documentation, [Yes, Not needed], but it does not work, and errors out.
Can someone please help us here?
The in-place documentation still suggests “Option [A, B]” to match either or both, “Option A” and “Option B”, whereas standard regular expressions would have “Option (A|B)” to match either – or in your case “(Yes|Not needed)”.
It works, thanks
Hi
try this format:
(Yes, Not needed)
i was also looking for that solution and then i began to search for regular expression examples and that worked for me.
cheers,
MY
