×Hello,
it would seem that the widget is calculating the current estimate incorrectly.
Here is a screenshot for 1 user
Then I clicked on the yellow pie to see the issues and they are showing this:
Now I cannot figure out, the pie chart says it's using "Current Estimate" but there is no such field from what I can find in Jira. If I add up any of the 3 timer columns, none result in the 1w 7:30 hours the pie is showing.
So what is the Pie Chart using as "Current Estimate"? Is there a bug in it?
Alternatively, is there another way to report on the remaining time estimate field?
Thank you
If you add up the remaining estimate values for that user, it matches the chart value of 1w 7h 30m. A "week" is 5 days for that sum.
That would explain it then. I thought a week was 7 days, sorry about that.
Thank you.
