I'd like to pull a report for time logged in issues with certain labels. For example, I have 5 projects with 4 phases in each and I'd like to pull the time logged for Phase 3 for all 5 projects combined. I can add the "Phase-3" label to my issues, and they will pull in a filter with this query (labels = "Phase-3"), but they still show up as "No labels" in the Worklogs report when I select "Labels" under the "Categorize by" drop down. Thoughts?
Hi @Ste Wright and @Wojciech Wardaszko ,
I should have been more clear. I'm using the add on called Worklogs by SolDevelo Products.
Hi Kurt,
Then it's best to reach out to their support team - they should be able to help you solve this issue.
I'm not familiar enough with their products to help you, sorry. I still hope they get it sorted out in no time.
Cheers!
Thanks! I put in a ticket with them and we'll see what they come back with.
Hi @Kurt Bandy
Is this a native report, or an App you're using?
You mention "Worklogs Report" - is it this App? - https://marketplace.atlassian.com/apps/1216516/worklogs-report?tab=overview&hosting=cloud
Ste
Hi @Kurt Bandy
I'd contact the vendor directly for this one.
For the App you mentioned, you can see their contact details on the left-hand side of their Atlassian Marketplace vendor page - see: https://marketplace.atlassian.com/vendors/1215650/soldevelo
Ste
Hi @Kurt Bandy
Welcome to the Community!
It would help us if you indicated what tool are you using to pull up those reports. Is this a built-in Jira report or are you using any time-tracking or timesheet app?
Cheers!
