Would like to edit custom field when creating an issue
Mike Espitia March 8, 2024
Hello I would like get help on editing a custom field as soon as a ticket is created with a condition found on the freshservice ticket?
Mike Espitia March 10, 2024
Yes I am creating an automation that when I Jira ticket is created and a condition is set then the automation edits the issue by selecting a Ticket Type and Category? But when I select edit issue  under Choose fields I can't find the fields I am looking for.
Asha Goyal
March 9, 2024
Hi @Mike Espitia
Could you please elaborate a little on your requirement?
Regards
Asha
John Funk
Hi Mike - Welcome to the Atlassian Community!
What exactly is your process and what exactly are you wanting to do and when?
John Funk
Are the fields on the edit screen for the project? If you pull up the ticket itself, can you edit those fields manually?
Mike Espitia March 11, 2024
Hello John, yes the fields where created in the custom field section and they were added to the project. I can open the ticket and edit it manually.
Like • John Funk likes this
John Funk
Which Category field are you trying to use? If it is the one on Jira Work Management projects, that field is not currently available in automation.
What type of field is the Ticket Type field?
Is this project a Company-managed or Team-managed project?
Mike Espitia March 14, 2024
the projects are under Company-Managed. The Ticket Type is a Selected List ( cascading) type.
John Funk
Can you share some screenshots?
Mike Espitia March 29, 2024
Thank you for your help John,
I was able to create the JSON scrpt:
"update": {
"Ticket Type": [
"set": {
"value": "Freshservice",
"child": {
"value": "Service Request"
This works with conitinals. Would like to know if there was a way to use regular expression from the comment to fill the values.
John Funk
You might can do that by creating a variable and then using the variable in the JSON.
Read the story
