Wrong French translation of Discard button in "Discard Draft Workflow" popup
Couleur_Connection December 12, 2019
When discarding workflow modifications on a draft workflow, a popup is displayed (titled "Discard Draft Workflow".
There are two butons in this popup : "Discard" and "Cancel".
In french, these two buttons are translated to "Annuler".
The "Discard" button must be translated to "Supprimer" as in the popup title "Supprimer le brouillon de Workflow"
Is there a work around to manually modify the translation ?
Because it's embarrassing to have two buttons with the same labels !
PS : Could someone submit the bug because I only have a starter licence so I can't submit it myself...
English screenshot :jira-workflow-bug-en.PNG
French screenshot :jira-workflow-bug.PNG
Walter Buggenhout
A ticket has been created for this issue.
Thanks !
Could you give me the issue link ?
Walter Buggenhout
It's a service desk ticket for now with ref CA-871319.
Ok. Thank you !
Johan Ferner
The exact same problem exists for Swedish too. Is there a public ticket or is this fixed?
Like • Couleur_Connection likes this
