Recently we have observed that incorrect attachments are displaying when viewing an issue.
As an example a new created issue (today) when viewed is showing that an attachment was added on 14/1/21. If you attempt to view it times out.
It's more of an issue with the customers.
We are experiencing this issue as well. As I was reading another board posting, I found that this is a known bug shown here. Hopefully that helps.
This is still happening 02/03
Although the file won't open the attachment name is still shown.
You are not alone, we are experiencing the same thing randomly in Jira software. After three or four refreshes the correct attachments or no attachments (which is correct) is shown on the issue. I have raised a ticket with Atlassian and will report back if they give me a solution or something to double check.
We have seen a similar issue with Attachments showing when we open an issue that is not actually attached to the issue, and when you go to click on them they do not open. Clients can not see these. And if you return to the issue later many times the ghost attachments are no longer visible. @Jennifer Skudlarek
