XML export fails on embedded DB
Riedl-Taras April 5, 2019 edited
I am migrating evaluation Jira server to datacenter (self hosted, VM)
And I want to export data to XML according to manual
https://confluence.atlassian.com/adminjiraserver073/migrating-jira-applications-to-another-server-861253107.html
However, this issue happens:
java.lang.NoClassDefFoundError: javax/xml/bind/DatatypeConverter
	at com.atlassian.dbexporter.node.stax.StaxStreamWriter$1.setContentAsBinary(StaxStreamWriter.java:108) [?:?]
	at com.atlassian.dbexporter.node.NodeBackup$RowDataNode.append(NodeBackup.java:238) [?:?]
	at com.atlassian.dbexporter.exporter.DataExporter.exportRow(DataExporter.java:171) [?:?]
I have seen https://confluence.atlassian.com/jirakb/jira-xml-backup-fails-throws-java-lang-noclassdeffounderror-javax-xml-bind-datatypeconverter-895910465.html
but how to do it with embedded DB?
How can I fix it?
Andy Heinzer
April 8, 2019
Hi Taras,
It is still possible to access the H2 embedded database.  We have a KB that details the steps needed to do so.  Please see Accessing JIRA's H2 embedded database for more details.
Once you follow that guide it should help provide you access to where you can then follow the steps in the second link you cited in order to delete the specific AO table with the BLOB data within it.
Try this and let me know if this helps.
Andy
