Xray cloud graphql - curl format error
Asitha March 25, 2024
I have been trying to utilise this grapqhl mutation to update a test plan with test executions.
https://xray.cloud.getxray.app/doc/graphql/addtestexecutionstotestplan.doc.html
While trying to do this via github actions I face an error with the json format.
Here ${{ needs.testex.outputs.executions }} returns an json array ["123","234"] etc..
curl -X POST -H "Authorization: Bearer $token" -H "Content-Type: application/json" -d '{"query":"mutation {addTestsToTestPlan(issueId: \"119\",testIssueIds: ${{ needs.testex.outputs.executions }}) {addedTests warning}}","variables":{}}' https://xray.cloud.getxray.app/api/v2/graphql
 But every attempt has met with either something like
{"errors":[{"message":"Expected type String, found 121335.","locations":[{"line":1,"column":78}]}...
or
{"error":"Server Error - Unexpected token \\ in JSON at position 75"}
Note :
It works if I hardcode like this.
curl -X POST -H "Authorization: Bearer $token" -H "Content-Type: application/json" -d '{"query":"mutation {addTestsToTestPlan(issueId: \"119\",testIssueIds: [\"123\",\"234\"]) {addedTests warning}}","variables":{}}' https://xray.cloud.getxray.app/api/v2/graphql
 Any help is greatly appreciated on this matter.
Register today
