Anyone else getting a Failed to load resource: the server responded with a status of 404 () for Zephyr in Jira? It doesn't matter what Zephyr function you're looking at- Plan Cycles or individual tests alike.
You should be able to use Zephyr with Next-Gen projects now. Please refer the article here on how to enable Zephyr for a Next-gen project.
Zephyr for Jira does not yet support Next Gen Projects, it works only for classic type of projects as of now. Next Gen support is on the roadmap of Zephyr and this should be available soon.
