Zephyr - "Add custom field" button disappeared
raghu_mankali March 15, 2020 edited
Dear Team,
I created 1 custom field in Zephyr custom field section for Test details and it worked as expected. But when I went back to add another zephyr custom field , "Add custom field" button is not available. Not sure if this happened for everyone. but its weird
Please help me here.
Sanjeev Pande
March 15, 2020
Hi @raghu_mankali ,
The page you are not able to see the Add Custom Field button is at the project scope.
You can only enable/disable custom fields in that page.
Adding custom fields are available only in the admin scope.
You need to navigate to Jira Settings -> Apps -> Zephyr Custom Fields page in order to add a new custom field
So, the way it works is; admins can create custom fields and for each project we can enable or disable them.
Hi @Sanjeev Pande .. You are right!! Its my bad that I got confused with navigation.
Thanks it worked fine.
Raghu vamshi
Like • 2 people like this
