addedAfterSprintStart using sprint name failed
jacob cheng June 13, 2023
When I use the JQL functions addedAfterSprintStart, document said
addedAfterSprintStart(board name/ID, [sprint name/ID])
 For the sprint is already closed, If I put the sprint ID, query is good. if put the sprint name, query report error: No Sprint with that name/id could be found for this board.
Any clue why name is not supported for closed sprint? Thanks
Tim Perrault
June 13, 2023
Hi @jacob cheng
When using the name make sure it has quotes around it and also the search is case sensitive. So if you have a sprint name SprinT 2 and a board named Test BoArd the query would look like this:
issueFunction in addedAfterSprintStart("Test BoArd","SprinT 2")
Thank you @Tim Perrault . that resolve the issue.
Like Tim Perrault likes this
