affectedVersion != version OR affectedVersion is EMPTY does not work
Florian Zink
Hi all,
a colleague recently wrote a JQL which amongst other things, filters on affectedVersion, f.e.
AND (affectedVersion != ABC_4.13.4  OR affectedVersion is EMPTY)
However, the result the query provides is only '!=ABC_4.13.4'. It does not list any issues where the affectedVersion is EMPTY.
Is this a bug or works as designed? Does anybody here now how to achieve the desired result?
Petar Petrov (Appfire)
July 10, 2016
This should work - there is probably something else in your query that filters those issues. Given the fact that you have an "AND" at the beginning tells me that what you have posted is just a subquery. Check what other conditions you have in the query and find the one that is restricting your issues from showing.
Florian Zink
Sadly it doesn't work. Even if I strip the query down to:
project = ABC AND fixVersion = ABC_4.13.4  AND (affectedVersion != ABC_4.13.4  OR affectedVersion is EMPTY)
Ok, I think this might be an index issue. Because if I do:
project = ABC AND fixVersion = ABC_4.13.4 and affectedVersion is EMPTY
I get 0 results.
However, if I do:
 I get 12 results, of which 6 apparently have an EMPTY affectedVersion.
atlassian, rovo agent workshop, rovo workshop series, build rovo agent, atlassian intelligence, ai agents, rovo in action, automation agents, ai for teams, atlassian learning, rovo development, agent building tutorial
[Workshop Series] Let's build a Rovo Agent
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
Upcoming Jira Events
