Hi...I have a selection list custom field where the values represent numbers (1,2,3,4,5)....is there a way I can use a JQL like this :....issueFunction in aggregateExpression("Total","customfield.sum()")....
When I try to run it I get an error message
Field found but has no searcher. Edit it, set the searcher, and re-index
is there a way to "convert" the selection field to number so the aggregateExpression can do the sum?
Thank you
You can add your own classes for JQL functions – Called Script JQL Functions.
If you are not comfortable with this, you may need to reach out to Adaptavist for consulting. This isn't something most people will do for free.
image2016-12-14 14:31:10.png
