i keep getting an outdated confirmation code on Jira verify your identity window
i click "Did not get the code. Resend it"
i receive new confirmation code
but when i try to enter it i get the error: "You entered an incorrect verification code"
This sh1t pisses me off
Welcome to community!
Please try the recommendation from https://support.atlassian.com/atlassian-account/docs/login-issues-related-to-identity-verification/
Make sure:
You're not entering any spaces between the six digits
You're looking at the code in the correct email
Your code hasn’t expired
Your device has the correct time
Also more explanation in https://support.atlassian.com/atlassian-account/docs/login-issues-related-to-two-step-verification/
If you know you’re using the correct verification code but your Atlassian account won’t accept it, make sure:
you’re entering the verification code as a single string, for example, 111000 instead of 111 000
you're looking at the correct verification app and the correct code for your Atlassian account, as many apps allow you to add several accounts and codes in the same app
the time for your app and phone are the same, and if they’re not, reset your phone’s clock and try to access your account again
If you've tried everything in this list, log in with your emergency recovery key.
