Hi there,
I believe the answer will be the same. This kind of association is only possible between two JIRA server instances.
Clarissa.
one is JIRA server and the other is JIRA cloud. can we link JIRA server with JIRA cloud?
thanks
Hi there,
I'm afraid it is not possible to associate tickets between two JIRA applications under different domains using JIRA Cloud. To create this type of link, it would be necessary to configure fully reciprocal application links between your JIRA site and the other JIRA site containing the issue(s) you want to link to, and that's not allowed in Cloud.
Clarissa.
