assign issue to reporter when jira issue transition
Ramaiah Pendli July 17, 2016
while move issue to other state the JIRA issue should automatically assign to the reporter, who is created a JIRA issue it should be assign in a particular transition.
Hi Jobin,
 post function: "assign to reporter" it's not there my JIRA 6.3.15 instance, is this required any plugin to visible the option.
Jobin Kuruvilla [Adaptavist]
July 18, 2016
oh ok! I am seeing in JIRA 7 and JIRA 6.4. It doesn't need a plugin.
July 17, 2016
You go the workflow transition and add a post function that says "assign to reporter". Publish the workflow after the changes and you should be good!
