authentification token atlassian
karim -Atlassway-
Banned
April 3, 2020 edited
hello Team
I used this for authentification
#!/usr/bin/python3.6
# library modules
from jira import JIRA
user = 'karim.belhadj@ovyka.com'
apikey = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
server = 'https://ist-efr.atlassian.net'
options = {
'server': server
jira = JIRA(options, basic_auth=(user,apikey) )
# print all of the project keys as an example
for project in jira.projects():
print(project.key)
I get this error  cannot import name 'JIRA' from 'jira'
Thank you
Carlos Garcia Navarro
Hi @karim -Atlassway-
I wonder if this article may help find the root of your problem: https://github.com/pycontribs/jira/issues/320
From the aforementioned article:
"There are a couple things that could be happening here.
A. There is a clashing jira.py
B. The python jira module is not installed at all
C. The python jira module is not installed for the correct version"
You can find more details regarding the problems and solutions in the article. I hope it helps.
Carlos
