automatic pdf email sender
Adam Wojak March 5, 2018
I'm trying to set an automatic email sender that will generate monthly raports per projects (i need to see: project, issue, worklog day, worklog reporter and time spent) and automatically send it to certain email address. I installed Work Time Calendar which works perfect (imgur), but i have to generate raport then download it and then send it and it takes a lot of time when there is a lot of projects.
I installed JIRA PDF View Plugin + Automation Lite For Jira + PDF Automation Plugin For JIRA, but it doesn't work as i would like to, it sends one issue in one page so when it's 300 pages with 300 issues, that's too much. I used in project automation "worklogDate <= 31d", but some months have less than 31 days and it probably won't work perfect.
Aron Gombas _Midori_
March 5, 2018
Solution to both of your problems:
PDF View Plugin enables you to customize the PDF template with insane flexibility. So, you can include the issue details you are interested in and exclude the rest. And you can remove the page breaks, as well.
(We are the developer of the app, so please feel free to ask us.)
JQL offers you a smart functions like startOfMonth(), endOfMonth(), etc.
See: https://confluence.atlassian.com/jirasoftwarecloud/advanced-searching-functions-reference-764478342.html
With this, your query would be something like:
worklogDate >= startOfMonth()
Adam Wojak March 6, 2018
But let's say that i want to send February's raport on 5th of March, using startOfMonth() would give me issues with worklogDate reported from 1st to 5th March, right?
March 6, 2018
You can use an "offset" argument with startOfMonth().
That way startOfMonth(-1) defines the start of the previous calendar month, while endOfMonth(-1) defines the end of the previous month.
