automation rule for Validate epic link
Edimara July 15, 2022
I need to build a valitation that when I make an epiclink action it compare if the issue has the same projectId than the epic parent
July 17, 2022
Hi @Edimara -- Welcome to the Atlassian Community!
What problem are you trying to solve by doing this?  For example, detect that someone has linked an epic to an issue which is in a different project.
You can perform this check by checking the project field of both issues: the trigger issue and the issue found by branching to epic.
Edimara July 18, 2022
I need to know when I have interdependence between projects (issue with epic link that don't belong to the same epic project
Kian Stack Mumo Systems
@Edimara
That is not possible out of the box. Do you have any plugins installed such as ScriptRunner?
Hi @Kian Stack Mumo Systems
I have scriptrunner
Register today
