automation rule to sum up original estimate of sub-tasks to parent is not working.
Kalai
July 28, 2024 edited
dear teammates,
my new automation rule to sum-up the sub tasks original estimate to parent (type = user story) is failed. Please help me to fix this issue. we usually have many subtasks to complete the user story. so fix on this automation is our at most need. also why we are unable to select original estimate field to set up the field? it throws error.
thanks,
Kalai
John Funk
Hi Kalai,
Can you share the rule that you have so far? And where it is failing - please sure the Audit log.
Kalai
sure John, I will share it now and thanks for the quick response.
Kalai
hello John,
please find the attached screenshots for your reference. and please review and advise me how to fix this issue?
thanks and regards,
Kalai
Like John Funk likes this
Kalai
Kalai
July 29, 2024 edited
other screen shotsRule step-4.png Rule step-3.png Rule step-2.png Rule step-1.png
John Funk
Well, I am sorry to be the bearer of bad news - but the rule is not even running because you are over your limit for rule  for the month. You can see that note in the bright yellow banner.
Hopefully, that will start over for your on August 1, but not sure when your month begins and ends.
Like Kalai likes this
Kalai
Hello John,
Good day.
thanks for your kind response. Yes i also noticed but i though since it is a newly created rule it will run and the status also enabled.
Let me wait for my month to restart and I will check and update here, then we will come to know whether the rule is working or not.
but by any chance did you notice any mistake in my steps?
Thanks & Regards,
Kalai
John Funk
It looks fine to me.  :-)
Kalai
hello John,
Good day.
As per our previous conversation my months restarted and the formula works now but the issue now I'm facing is the time I'm entering in "h" on sub task but my parent is calculating hours wrongly. attached is the screen shot for your reference. also i didn't change any formula which i have given in my previous screenshot.
Kindly advise me.
John Funk
Try dividing by 360
FREE
atlassian, rovo agent workshop, rovo workshop series, build rovo agent, atlassian intelligence, ai agents, rovo in action, automation agents, ai for teams, atlassian learning, rovo development, agent building tutorial
[Workshop Series] Let's build a Rovo Agent
AI-curious? This series walks you through building Rovo Agents step by step, no matter your experience level. Multiple workshops available throughout October and November!
Register now
Upcoming Jira Events
