Sign up Log in
automation set field to current user
Jeff Pak
February 27, 2025
i have a custom field called 'end-to-end owner'
i wish to set 'end-to-end owner' as the user who creats a sub-task ticket
how can i set up the automation?
3 votes
Manne Kjærby - ProProces
Hi Jeff.
Welcome to the community :-)
You can create a automation that looks like this:
Instead of assignee, set the field to end-to-end owner and then choose either the user who triggered the event or Issue creator.
If you don't know how to find automations, its within the project settings and then automations.
Hope this helps you.
Kind regards
Manne
Vikrant Yadav
February 27, 2025
Hi @Jeff Pak ,
Trigger : Issue Created
Condition : issue type = Sub-task
Edit Issue : Select Field "End-to-End Owner" and add smartvalue {{initiator}}
Karan Sachdev
February 27, 2025
hey @Jeff Pak,
Can you please clarify if you want to set this field on the Parent issue with the subtask's reporter or do you want to set this field on the subtask itself?
Based on that, you can either use branch in your rule to make it work for the Parent issue, or directly add an "Edit Issue" action in the rule to update the subtask only.
Karan
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
