bulk create jiras
xiangbao song
August 28, 2024
days a ago i can multiple create jira task by click create button - bulk insert , but today i can not find the button, where i can find the function instead ? thanks.
Cristian0791
August 28, 2024
Hi xiangbao,
  1. Select Filters > Advanced issue search.
  2. Click more ( ••• ) > Import issues from CSV
  3. Choose the CSV source file that you want to import. Check the If you don't have a configuration file or you want to create a new one, leave the Use an existing configuration file option unchecked. Configuration files specify a mapping between column names in your CSV file's header row and fields in your installation. You will have the option of creating a configuration file at the end of the import process.
  4. Click Next and fill in the required information. If your CSV file uses a different separator character other than a comma, specify that character in the CSV Delimiter field. If the separator is a tab, this can be entered using the format "/t".
  5. Click Next and map the column headers of your CSV file to the fields in your selected project. If you want to select specific Jira field values to map specific CSV values to, check the Map field value option. You must map a CSV field to the issue summary field, as all issues created must have a summary.
  6. Click Next one more time and select which CSV field values selected in the previous step you want to map to specific issue field values. For example, you might want to map the CSV field value of "Feature Request" to the Jira issue type field value "New Feature".
  7. Click Begin Import when you are ready to begin importing your CSV data into Jira. If you want to check for any errors or warnings, click Validate before beginning your import. If you want to import another CSV file with similar settings (e.g. similar field value mappings), you can save the configuration by downloaded a CSV configuration file.
You can find here the full Atlassian article: https://support.atlassian.com/jira-software-cloud/docs/create-issues-using-the-csv-importer/
xiangbao song
August 28, 2024
thanks for your replay, totally resolved my question.
